jamessawle2
Sep 12, 2017Aspirant
Detected increasing uncorrectable error count
I have what I think is a drive failing, but I cannot locate in the manual what I need to do to replace this drive? It seems to be Disk 2 but I cannot tell which phsyical drive this is, as in do t...
Sep 12, 2017Guru - Experienced User
Drives are numbered left to right, and start with 1.
You can confirm this when you remove it, since the serial number is also in the log.
Note you can also download the log zip file and look at disk_info.log.
- jamessawle2Sep 12, 2017Aspirant
Thanks for this, I tried to download the log but it would not allow me too, The whole unit is running like a dog and I suppose that this is because of the drive failing. I have now shut down the unit and ordered a replacement, will replace when it arrives in a day or two and hopefully have the drive up and running.,.. Thanks for the info though, VERY much appreciated...
James
Sorry about the duplicate, but this was not down to me as such, I tried to post it but it did not like the description and would not allow me to post until i changed it, but when I changed the header and it posted I noticed that it had actually posted the original message in the end even though it kept telling me that it could not be posted until i change the header.
Sorry
James
