jamessawle2
Sep 12, 2017Aspirant
Detected increasing uncorrectable error count
I have what I think is a drive failing, but I cannot locate in the manual what I need to do to replace this drive? It seems to be Disk 2 but I cannot tell which phsyical drive this is, as in do t...
Sep 12, 2017Guru - Experienced User
Drives are numbered left to right, and start with 1.
You can confirm this when you remove it, since the serial number is also in the log.
Note you can also download the log zip file and look at disk_info.log.
jamessawle2
Thanks for this, I tried to download the log but it would not allow me too, The whole unit is running like a dog and I suppose that this is because of the drive failing. I have now shut down the unit and ordered a replacement, will replace when it arrives in a day or two and hopefully have the drive up and running.,.. Thanks for the info though, VERY much appreciated...
James
