jamessawle2
Sep 12, 2017Aspirant
Detected increasing uncorrectable error count
I have what I think is a drive failing, but I cannot locate in the manual what I need to do to replace this drive? It seems to be Disk 2 but I cannot tell which phsyical drive this is, as in do t...
Sep 14, 2017Guru - Experienced User
Are you seeing any messages that is it syncing? Does the volume tab show both drives as part of the array?
Perhaps post a screen shot of your volume tab (you can do that if you see the "photos" icon in the "rich text" toolbar here).
With Windows, you can enter ctrl+print screen (might be labeled PrtSn or something similar) to capture the window. Then you can open paint and enter ctrl-v to paste it. You can crop it if needed, and then save it as a PNG. Then attach the PNG file using the photos icon.
jamessawle2
Sep 14, 2017Aspirant
Looks to be working, left it for an hour and come back to see that its at least doing something, hopefully will be up and running by tomorrow...
