beaudettee
May 02, 2013Aspirant
Dierect-connect two readeyNas Pros using second eth port
Hi All: For purely performance issues, I am considering direct connecting the second Ethernet port on each of my two RDNP6000 using a cross-over cable. I am thinking of setting up the second port on ...
mdgm-ntgr
May 02, 2013NETGEAR Employee Retired
No need for a cross-over cable (though you can use one if you really want to) as the NICs are auto-sensing. A standard ethernet cable would be fine.
