beaudettee
May 02, 2013Aspirant
Dierect-connect two readeyNas Pros using second eth port
Hi All: For purely performance issues, I am considering direct connecting the second Ethernet port on each of my two RDNP6000 using a cross-over cable. I am thinking of setting up the second port on ...
May 29, 2013Guru - Experienced User
You'd save yourself a lot of time and trouble by getting an inexpensive gigabit switch instead (and forgetting about the dual-homing idea). You'd get better results also. This assumes cat-5e cabling (at least between the 2 ReadyNAS and the switch).
