beaudettee
May 02, 2013Aspirant
Dierect-connect two readeyNas Pros using second eth port
Hi All: For purely performance issues, I am considering direct connecting the second Ethernet port on each of my two RDNP6000 using a cross-over cable. I am thinking of setting up the second port on ...
beaudettee
May 29, 2013Aspirant
Thanks for the reply Stephen. Using the direct-connect on both port 2's (on a separate subnet) does actually work like a charm (speed-wise), but by adding a switch (and a new subnet) just going to add an extra hop to the link? Is the ReadyNas smart enough to use the shortest route/interface if both are on the same subnet? With the exception of the gateway "bug" (which it is, IMO a bug) it works fine.
Thanks again!
Thanks again!
