greenlinkweb's avatar
greenlinkweb
difference between RN31442D & 31442E
Hi Sorry if this has been discussed before! Im new to NAS looking at the RN314 but wondering if there is an advantage to purchasing the one prepackaged with drives or just buying the unit and adding ...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 05, 2015
    The model ending in E has enterprise disks. The model ending in D has desktop disks.
    If you want to add your own disks make sure they are on the compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
    The default RAID configuration is X-RAID2 which uses RAID-5.
    I have the D7000 too. It's a great new ADSL2/VDSL modem/router.
ProSupport for Business
