dhinesh
Mar 11, 2013Aspirant
difference between RNDP 6620 & 6630
Currently using the Pro Business 6 bay readynas with 6 x 2tb harddisks. Would like to change these to 6 x 3tb harddisks. Do I just pull out the 2TB harddisks 1 by 1 and replace them with the 3TB hardd...
mdgm-ntgr
Mar 11, 2013NETGEAR Employee Retired
Another thing you should note is that you need to update to RAIDiator-x86 4.2.16 (or later) if you haven't already before adding 3TB disks.
