ronaldvr2132
Jan 29, 2020Apprentice
Disappearing iSCSCI drive on RN628X
Since 2018 (since the update to firmware 6.9.4) I have the issue with my RN628X that the drive that I linked to my windows 10 PC via iSCSCI is disappearing. The changes that the drive disappears seem...
Marc_V
Mar 31, 2020NETGEAR Employee Retired
Sorry for the late response. Can you provide a screenshot of any error you are experiencing.
Are the LUNS still on the NAS? It is just the target the disappeared on the Computer?
Have you checked if there were any network changes?
Regards
ronaldvr2132
Apr 21, 2020Apprentice
There is nothing to screenshot. I have a D drive, it disappears without any message and surfaces again later as well. It seems the NAS is quity busy, but I don't have a clue what it is doing. Other than indexing and the antivirus services, which I would not expect to have a big performance impact when not a lot of files are changing I don't do anything that for me could explain that the NAS is so busy. Anyway I disabled the iSCSI drive and attached an external hard drive which is now working just fine.
- StephenBApr 21, 2020Guru - Experienced User
It also be a network issue.
- ronaldvr2132Apr 21, 2020Apprentice
That could well be and iof so than I suspect my Netgear Orbi set. This set is running in AP mode and I have noticed quite some times that my wired network becomes unresponsive when I work on the settings of my Netgear Orbi or perform a firmware update. Lately I tried to reinstall the same firmware as the Orbi does not show the connected devices any longer and then a lot of wired connections got disrupted. Ao it seems the Oribi is creating a kind of storm on my wired ethernet.....
What Orbi model do you own? I use the RBK50, and haven't run into any recent issues (though I use it in router mode with ethernet backhaul).
