pnwttc
Sep 10, 2014Aspirant
Disc Scrubbing Fails following 2 x 2Gb Memory Upgrade
Hi All, I've updated the memory in my ReadyNAS Pro 6 (which is populated with 6 x 1TB Seagate Drives with xRaid2 and dual drive redundancy) from the standard 1 x 1Gb DDR2 (6-6-6-18) to 2 x 2Gb DDR2...
pnwttc
Have ran memory test for 6 cycles with no errors
I then removed one of the memory stick so the NAS only had 1 x 2GB RAM and the scrubbing worked fine. So it appears the issue is related to the use of 2 memory sticks and not the memory itself
Martyn
Martyn
