pnwttc
Sep 10, 2014Aspirant
Disc Scrubbing Fails following 2 x 2Gb Memory Upgrade
Hi All, I've updated the memory in my ReadyNAS Pro 6 (which is populated with 6 x 1TB Seagate Drives with xRaid2 and dual drive redundancy) from the standard 1 x 1Gb DDR2 (6-6-6-18) to 2 x 2Gb DDR2...
pnwttc
Sep 11, 2014Aspirant
Yes, probably, but what is odd is that I currently have a single 2Gb memory stick from one of the kits installed and the scrubbing works perfectly. In fact it works on either of the 2Gb sticks from a kit, its only when both are installed at the same time it fails
Martyn
Martyn
