fixit9660
Nov 15, 2017Aspirant
Disk Removal Detected but all looks ok? ReadyNAS NV+ V2 running 5.1.13
Hi. Over the last few days I've tried to create a new Windows 7 VHD which took days, so I aborted it. In investigating why it was taking so long I discovered that the NAS network interface was only r...
Nov 15, 2017Guru - Experienced User
If RAID appears to be rebuilding, then I'd wait for that to finish.
If you don't have a backup, then it would be prudent to make one.
- fixit9660Nov 16, 2017Aspirant
That's just it; nothing appears to be happening. No rebuild or anything that I can determine. Is there a way to trigger a rebuild from the CLI or should I just yank it out/bung it back in?
- StephenBNov 16, 2017Guru - Experienced User
Try hovering over the volume and disk icons in RAIDar (or the admin web ui) and see if you get more status info.
No more info than is already on offer I'm afraid. Is there a way to kick-off the RAID rebuild manually from the CLI, or should I just "do it"?
