fixit9660
Nov 15, 2017Aspirant
Disk Removal Detected but all looks ok? ReadyNAS NV+ V2 running 5.1.13
Hi. Over the last few days I've tried to create a new Windows 7 VHD which took days, so I aborted it. In investigating why it was taking so long I discovered that the NAS network interface was only r...
Nov 15, 2017Guru - Experienced User
If RAID appears to be rebuilding, then I'd wait for that to finish.
If you don't have a backup, then it would be prudent to make one.
fixit9660
Nov 16, 2017Aspirant
That's just it; nothing appears to be happening. No rebuild or anything that I can determine. Is there a way to trigger a rebuild from the CLI or should I just yank it out/bung it back in?
- StephenBNov 16, 2017Guru - Experienced User
Try hovering over the volume and disk icons in RAIDar (or the admin web ui) and see if you get more status info.
- fixit9660Nov 16, 2017Aspirant
No more info than is already on offer I'm afraid. Is there a way to kick-off the RAID rebuild manually from the CLI, or should I just "do it"?
You can try removing the disk with the NAS running, and then re-insert it (also with the NAS running).
It'd be wise to make sure you have an up to date backup first.
