fixit9660
Nov 15, 2017Aspirant
Disk Removal Detected but all looks ok? ReadyNAS NV+ V2 running 5.1.13
Hi. Over the last few days I've tried to create a new Windows 7 VHD which took days, so I aborted it. In investigating why it was taking so long I discovered that the NAS network interface was only r...
fixit9660
Nov 16, 2017Aspirant
That's just it; nothing appears to be happening. No rebuild or anything that I can determine. Is there a way to trigger a rebuild from the CLI or should I just yank it out/bung it back in?
Nov 16, 2017Guru - Experienced User
Try hovering over the volume and disk icons in RAIDar (or the admin web ui) and see if you get more status info.
- fixit9660Nov 16, 2017Aspirant
No more info than is already on offer I'm afraid. Is there a way to kick-off the RAID rebuild manually from the CLI, or should I just "do it"?
- StephenBNov 16, 2017Guru - Experienced User
You can try removing the disk with the NAS running, and then re-insert it (also with the NAS running).
It'd be wise to make sure you have an up to date backup first.
- fixit9660Nov 17, 2017Aspirant
I take it there's no way to kick-off the RAID rebuild at the CLI then. Oh well, I removed the disk, waited a few minutes and in that time the NAS recognised the disk failure/removal. When I re-inserted the disk it thought it was a new disk, tested it, and then started to re-sync. It didn't recognise it as a disk that was previously in use, should it have done?
I've historically had problems with disk 1 on this NAS. Also opening and closing the door causes the NAS to "chirp" a lot of the time. When I first got it, it did this, and after a Support call the NAS was replaced, and the new one did/does the same, so I've assumed it's "normal" behaviour although I can't think why it should be.
