yusahtr33
Sep 03, 2016Aspirant
DLNA disconnect
While I'm streaming a video to my TV through DLNA my readynas 104 will disconnect randomly. I have the latest firmware. 6.5.1. Anyone else having issues like this?
yusahtr33
Sep 11, 2016Aspirant
No the behavior is only on my TV. When I stream on my computer it works fine.
- BrianL2Sep 11, 2016NETGEAR Employee Retired
Hi yusahtr33,
What was the brand of your TV and how does it connect to your network (LAN or WLAN)?
Kind regards,
BrianL
NETGEAR Community Team- yusahtr33Sep 12, 2016Aspirant
it's a mitsubishi 5570 and i use WLAN to connect via DLNA
- BrianL2Sep 13, 2016NETGEAR Employee Retired
Hi yusahtr33,
Have you considered connecting your TV via LAN to check if the issue will persist? I can say that the problem is only with your TV since other DLNA enabled devices like your PC has no problems accessing the video files from your ReadyNAS.
Kind regards,
BrianL
