BrianMarkussen
Jun 26, 2012Aspirant
DLNA Failes in rescan.
Hi i have the nas sparc model. I have Samsung 40ES6715 2012 Led. I run radiator 4.18 and the newest dlna from Skywalker 1.0.24.3 I have made a folder called HD_Movies and have aprox 200 MKV 108...
Jun 26, 2012Guru - Experienced User
The bandwidth savings are inconsequential (and MKV is NOT used in videoconferencing! RTP is generally used, and it does not handle variable frame rate that way).
BTW, the vid2eva conversion tool at vid2eva.lefti.net includes the ability to remove header compression/stripping from all MKVs in a folder. It looks at each MKV in the folder (and subfolders) for header compression, and if it finds it, rebuilds the MKV in place to remove it. (http://vid2eva.lefti.net/viewtopic.php?f=6&t=7). This requires Windows XP or later. If you want more info, PM me (or better still join the vid2eva forum).
