BrianMarkussen
Jun 26, 2012Aspirant
DLNA Failes in rescan.
Hi i have the nas sparc model. I have Samsung 40ES6715 2012 Led. I run radiator 4.18 and the newest dlna from Skywalker 1.0.24.3 I have made a folder called HD_Movies and have aprox 200 MKV 108...
Jun 27, 2012Guru - Experienced User
I guess that what this comes down to is that ReadyDLNA's scanning is not very robust. For whatever reason it is not handling header stripping (doesn't really matter much why), and there are other posts here that describe similar symptoms with other nedia files. There is a ReadyDLNA debug add-on which might help find the files that are provoking the failures.
