juicemanfta
Sep 07, 2011Aspirant
DLNA Not Working.
I just bought this ReadyNAS NV+ on the weekend, set it up and enable DLNA. I have a Boxee Box and Pioneer Receiver VSX52. Both device are having trouble with DLNA – Slow and timeout browsing. I con...
arjoseph1
Sep 13, 2011Tutor
Try these steps:
* disable and re-enable ReadyDLNA
* if it will still not work disable ReadyDLNA, turn off NAS, turn it on, then re-enable it
* if it will still not detect the media files uninstall ReadyDLNA software and re-install it
* make sure that auto media scan is also enabled
