klind
May 04, 2011Aspirant
DLNA not working with Samsung TV
Hi, I just got a NV+ 4210 I enabled the DLNA service and I can connect with my windows media player on my lap top to the ReadyNAS. I have a samsung tv with DNLA, I have used my old NAS, a synol...
Accolon
May 15, 2011Aspirant
Hi There,
I've come to my final solution:
I'm using a TV receiver connected through the internet.
Apparantly this starts a service on the router called "QoS". This is necessary for my bluewin TV (thats my provider, I'm from switzerland) to work. If i plug the TV receiver out suddenly my TV sees the NAS.
This service is probably only necessary on newer routers, since TV and my NAS work both fine when pluged in the old router.
My solution is to put a switch, or in my case the old router as a switch, inbetween and connect only my old router (with all the devices at it) and the TV receiver to it.
I havent done it so far, but i'm about to do it, and it should work.
I'll post my 'solution' also in the other Thread discussing a similar problem.
Samuel
Samuel
