ScottyPottie
Apr 25, 2009Aspirant
DLNA Playlist
Hello, Are playlists supported? If so what format do they need to be in? I can't get them to show up on my devices. Photos and MP3s are working fine. Update: Just in case support is going to b...
alokeprasad
Mar 01, 2012Mentor
Where do you keep the m3u files? In each individual directories? In the root directory that ReadyDLNA is scanning/monitoring?
What directory names do you use in the m3u files to refer to the target mp3 files? relative addressing?
