algiam
Mar 16, 2016Aspirant
DLNA problems
Hello, I have the ReadyNAS 104 and have problems with DLNA. With video files of about 13GB and higher in scenes with a high bitrate the picture freezes for a few seconds. I use a Philips TV that ...
algiam
Mar 17, 2016Aspirant
thanks for answering
The video from the PC working properly.
I tried Plex, subsonic, neromediahome and always the same problem.
Today I've been playing with the MTU of the network card and depends on the value, the problem is aggravated or improvement. I will try to find the value that works best.
Before RN104 had a 1-bay NAS zyxel that cost me 50 € and did not have these problems, the NAS used Twonky and all perfecte.
Thank you,
Mar 17, 2016Guru - Experienced User
You shoul use 1500 if you don't kow the MTU of the network. You can also probe the path MTU with ping. http://www.tp-link.us/FAQ-190.html
