elric53
Sep 21, 2014Aspirant
DLNA problems?
Hi, I think this may be a common problem as I've seen similar posts in this forum but haven't managed to find a solution that works for me. I have a ReadyNAS 104 and have the latest firmware (6.1.9...
Sep 22, 2014Guru - Experienced User
Often this problem occurs because a specific media file is causing the media scan to crash, so it never completes.
Are you seeing all the files in the video folder? You could try turning DLNA off for all the shares, and try enabling them one at a time (re-scanning, and checking to see if you are seeing them externally before moving to the next)). Do video last.
