aszarith1
Aug 06, 2011Follower
DLNA showing multiple entries
Hi Everyone Got an odd one, I have a ReadyNAS Ultra+ and recently it has started showing multiple entries of any video content I upload, and I am not talking one or 2, there can be 40+ copies of th...
gogher
Feb 29, 2012Aspirant
here is the same on DUO V2. The problem seems to be related to some letters (,à,-,_.. or combinations of those in the file name. I haven't found any solutions, but still waiting for a NETGEAR fix. the only workaround i found, is to recreate the volume and copy back the files after i have renamed them on the source... it seems to be a DLNA SERVER fault only. can you confirm it ? infact if i try to rename the file on the NAS, on that side (disk) everything will be fine, but on DLNA part no rescan action will be performed and only one entry will be renamed, bul the others keep the old, wrong name.
bye
bye
