avpman1
Mar 05, 2011Aspirant
Does anyone have Crashplan running?
I successfully installed and was running Crashplan just fine on my NVX. After Crashplan was auto-updated to version 3.02 it stopped working. Interested to hear from anyone if they are having the same ...
fbmachines
Apr 20, 2011Guide
buynov wrote: Did anyone tried to run CrashPlan on RedyNAS Duo (Sparc)? Are there instructions anywhere on how it can be installed?
I got response from CP support that ReadyNAS installations are not supported.
You can't run CrashPlan on a Duo, or any other Sparc ReadyNAS, as it requires Java which isn't available for Sparc.
