jpullam
Nov 12, 2015Guide
Does the ReadyNas 100 offer power on restart?
I have a ReadyNAS Duo and am looking at replacing it as it is getting old. My one criticism of that box is that after a power failure, it does not reboot so someone has to be there to push the start ...
- Nov 20, 2015
jpullam wrote:
I don't think you answered my question. I'm guessing that your answer is that "no, current products do not have a power on boot capability." If so, there must be others facing this same issue.
My RN202 (and I think the RN102) will restart on their own if I pull the plug and then re-insert it. Though I haven't needed to do that with 6.4.x, I believe that is still the behavior.
But If they shut down normally for any reason (including a UPS power critical event), I need to push the power button. I believe WoL can be used to boot them remotely, but I haven't tried that. Some people have asked for different behavior as an option, so far Netgear hasn't provided it.
jpullam
Nov 20, 2015Guide
Nov 20, 2015Guru - Experienced User
