CrysManObs
Nov 23, 2014Aspirant
Drive replacement rebuild status
Hi, I started a vol expansion on my ReadyNAS Pro Bus, replacing drive 1 with a new 3TB drive (ST33000650NS on the HCL, my 2nd one). I'm on RAIDiator 4.2.27, configured as X-RAID2. The drive tested f...
vandermerwe
Nov 23, 2014Master
What other drives are in the nas currently?
What drives were in the nas when it was initially setup and was this the last time the unit was factory defaulted?
Do you have a backup?
If you don't have a backup, then make one now, then reboot the nas, perhaps a few times if the rebuild doesn't start.
If you have a backup you can either try removing the drive and reinserting it after the nas recognises a drive removal ;and/or reboot the nas.
I suspect a reboot is all that is required.
