CrysManObs
Nov 23, 2014Aspirant
Drive replacement rebuild status
Hi, I started a vol expansion on my ReadyNAS Pro Bus, replacing drive 1 with a new 3TB drive (ST33000650NS on the HCL, my 2nd one). I'm on RAIDiator 4.2.27, configured as X-RAID2. The drive tested f...
CrysManObs
This is the 3rd drive replaced in +5 yrs, but it's been so long since last time, I couldn't remember exactly how resync status was supposed to be reflected. Turns out it just needed to be re-seated. I should have noticed I was missing the very last log message before it really started the resync:
With that, resync appears running fine.
Thanks
RAID sync started on volume C.
Thanks
