PaulioF
Aug 29, 2017Aspirant
Drive transfer
Hi, I have an Ultra 4 and want to move the drives over and use them in a Rnd-4D. Will the drives just swap over or will I need to use a backup/re partition etc on the new box? Thanks
Aug 29, 2017Guru - Experienced User
I don't know what model you mean by RND-4D.
if you have an ultra-4 running OS 4.2, then you can swap over your disks to other OS 4.2 systems (other ultras or pros). All of those are discontinued models at this point.
But you can't migrate disks to OS 4.1, OS 5, or OS 6 platforms.
In the specific case of OS 6, you can temporarily mount the ultra volume as read-only in a new X86 NAS, so you can copy the data off. That is described here: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
- SandsharkAug 30, 2017Sensei
RND-4D is an RN104. I doubt the 104 is a lot faster than the Ultra4. I would have suggested migrating the Ultra4 to OS6 instead of getting the 104 if the Ultra is still functional. Both do require re-formatting the drives.
- PaulioFAug 30, 2017AspirantMy main reason for changing is that the Ultra 4 seems to be running very hot lately and hoping that with the RN104 having an external power block may run cooler?
I'll have to look into OS6 as to be honest, I thought that the versions they had was the latest / best it was capable of (It's running something like 4.1.27 (off the top of my head!) - StephenBAug 30, 2017Guru - Experienced User
The RN104 is arm-based, so the migration link I posted above doesn't apply. You'd need at least an RN 300 series (RN314) or perhaps an RN424.
I think the RN104 is actually a bit slower than the ultra. The RN214 (also arm-based) is definitely faster, particularly on writes.
