2Nutz
Jan 09, 2013Aspirant
Drive Tray Screws , Case # 20304575
Does anyone have a known source for the correct drive tray screws for the NV+ ??? Just acquired a used unit without drives or screws. No dice going to the hardware store. Based on others attempts...
Apr 01, 2013Guru - Experienced User
If the trays have the round button, you might want to replace them anyway. You could try googling for RND4TRAY1-10000S, and see if you can find any trays with screws.
Though the nicest solution would be if one of the netgear folks could help out.
Given how often this comes up, it would be helpful if someone could post a link to replacement screws that fit - especially since the RN1xx/3xx/5xx line uses a new tray design (which doesn't use screws btw).
EDIT - there is a detailed diagram in this thread that could help if you are looking for substitutes. viewtopic.php?f=20&t=18658
Papabear also posted a link some time ago suggesting that these would work: http://discountechnology.com/Counter-Su ... gory=18627. They will ship to the UK.
- Oct 02, 2015Retired_Member
