2Nutz
Jan 09, 2013Aspirant
Drive Tray Screws , Case # 20304575
Does anyone have a known source for the correct drive tray screws for the NV+ ??? Just acquired a used unit without drives or screws. No dice going to the hardware store. Based on others attempts...
Ed_J
Apr 10, 2013Aspirant
Hi,
Thanks for the replies, didn't get notification of them and hadn't been online for a bit due to a family bereavement.
BMach - I've done just that with the four screws at the back, holding the sideplates on, for disc 1 and used normal domed screws for disc 2. Could do with complete solution for when I add disks 3 and 4 though.
StephenB - I'd also found that detailed drawing - might need to try some online hardware suppliers in the UK to see if they can help. Like you say it would be nice if the Netgear guys could help out, even if just posting a link to known replacements. Given these are user serviceable parts, they should have catered for them getting lost/damaged.
- Oct 02, 2015Retired_Member
