2Nutz
Jan 09, 2013Aspirant
Drive Tray Screws , Case # 20304575
Does anyone have a known source for the correct drive tray screws for the NV+ ??? Just acquired a used unit without drives or screws. No dice going to the hardware store. Based on others attempts...
chirpa
Apr 12, 2013Luminary
You should check with Support again, the agent you spoke to obviously wasn't well informed. They do have the screws available.
- Oct 02, 2015Retired_Member
