hh1011
Nov 03, 2014Aspirant
Drive Upgrade from 1TB to 2TB
I've been using a ReadyNAS Duo RND2110 for home backups for several years now. I have about 675 GB of data and want to upgrade both drives from 1TB to 2TB. I'm seeking input on drive recommendations...
mdgm-ntgr
Dec 22, 2014NETGEAR Employee Retired
Yes, 2TB disks are the way to go with the v1.
3TB drives will be recognised with <1TB capacity in the Duo (v1). They are not supported in the Duo (v1) as the Duo (v1) does not support GPT partitioning.
