Sandshark's avatar
Sandshark
Sensei
May 02, 2019
Driveless system auto-updated flash firmware
I have been playing around with a semi-functional RD5200 running OS6.9.5 (yes, a ReadyData configured as a ReadyNAS). The problem it has can make the drives not visible at boot. When that happened, I was surprised that the OS on the flash had updated itself to 6.10.0, as visible on the monitor screen and also in the UI once I got it to recognize a drive. I re-imaged it to 6.9.5 and tried it again, first with the Ethernet disconnected (no update) and then with it connected (it updated). Is this something new? I can see why there could be a desire to insure newly installed units have the most recent firmware. But booting with no drives is a troubleshooting tool we often recommend, and having the flash firmware updated in the middle of troubleshooting another problem is a recipe for disaster.
Do we need to start telling folks to pull the Ethernet cable before booting with no drives and then insert it after the NAS has had time to boot? When I did that, it didn't update the flash. Or is this something unique because I have a chassis that identifies itself as an RD5200? If it weren't for the warnings about going back to 6.9.x from 6.10.0 and the fact I'm not convinced 6.10.0 is really stable, I'd just try it on another NAS.
  • StephenB's avatar
    Sandshark wrote:
    Do we need to start telling folks to pull the Ethernet cable before booting with no drives and then insert it after the NAS has had time to boot? .
    JohnCM_S :  I agree with Sandshark that we need to understand when the NAS will update it's flash while diskless, and how to prevent that.
    Can you provide some guidance on this?  Otherwise we'll need to tell folks to pull the ethernet cables and reinsert them after - which is annoying to say the least.  Also if the NAS doesn't have an LCD panel, it will be hard to know when it's safe to reinsert the cable.
    • JohnCM_S's avatar
      JohnCM_S
      NETGEAR Employee Retired
      Hi Sandshark, StephenB,
      The system needs a volume to perform a firmware update so a diskless system updating itself is not normal. Also, the system will notify you if there is an update available but not just upgrade.
      • StephenB's avatar
        Any explanation for what Sandshark is seeing?
ProSupport for Business
