Sandshark
May 02, 2019Sensei
Driveless system auto-updated flash firmware
I have been playing around with a semi-functional RD5200 running OS6.9.5 (yes, a ReadyData configured as a ReadyNAS). The problem it has can make the drives not visible at boot. When that happened, I...
JohnCM_S
May 03, 2019NETGEAR Employee Retired
The system needs a volume to perform a firmware update so a diskless system updating itself is not normal. Also, the system will notify you if there is an update available but not just upgrade.
May 03, 2019Guru - Experienced User
Any explanation for what Sandshark is seeing?
- JohnCM_SMay 03, 2019NETGEAR Employee Retired
Hi StephenB,
I am not sure what caused his RD5200 to just update without any disks. I checked this with L3 and said that it is really not normal and they cannot really explain how that happened. They said that the RD5200 with an OS6 firmware is a hack and unsupported. They do not know if the hack allowed the system to "see" a volume and update the firmware without any drives installed.
- SandsharkMay 04, 2019Sensei
It's definately not accessing any disk when it does this. But, there is a unused section of the USB that it might be doing something with. I cloned the 256M USB boot drive from a RN4200V2 to the 512MB one from the RD5200. But it still comes up not showing any drives when the problem occurs, which makes me think that's not it.
- SandsharkJul 16, 2019Sensei
FYI, it did the same thing on an RN4200V2. I can only guess it's due to the flash drive being a USB device, and thus a "disk".
I was testing the bays, and one row didn't work -- had a loose cable. So, it booted as a diskless system. After I fixed it and re-booted, it updated the volume to 6.10.1, though I had installed 6.9.5.
