chasdrury
Oct 27, 2015Aspirant
Dropbox integration
Hi So I want to use DropBox sync - the intial sync has worked for one folder - should i be able to choose multiple shares to sync to dropbox or is it only one at once? Once the sync is set up...
JennC
Oct 27, 2015NETGEAR Employee Retired
Hello chasdrury,
Welcome to the community!
Unfortunately, it is by design that Dropbox of ReadyNAS allows you to sync only one share at a time.
This has been raised before and we have already requested for for it as an added functionality.
- chasdruryNov 02, 2015Aspirant
Thanks
That's a real shame but good the feature has been requested. It works really nicely for one folder!
