sasdotcom
Jul 06, 2017Aspirant
Dropbox sync hangs - Firmware 6.7.5
My ReadyNas 204 (firmware 6.7.5) still hangs on syncing with dropbox. The total size of the folder is 185GB updating 19GB every day (max filesize is 2GB). I have to restart it every 2/3 days, then...
JennC
Jul 11, 2017NETGEAR Employee Retired
Hello sasdotcom,
Are you copying from the NAS to the DropBox Cloud? I'm not sure how you check this that shows it hangs but it could be because of the size of the files.
All files uploaded to your Dropbox must be smaller than your storage quota. For example, if your account has a storage quota of 2 GB, you can upload one 2 GB file or many files that add up to 2 GB. If you are over your storage quota, Dropbox will stop syncing.
Is your storage qouta more than 2GB?
- sasdotcomJul 11, 2017Aspirant
hello, my dropbox is 1TB with 800Gb free, and i've always used it for backup purpose for 2 years syncing it trough windows pc. i just hoped to do the same with readynas without having to use a dedicated pc.
Best regards
- GuyAAug 02, 2017Aspirant
We have the same issue. Files all less than 100MB, trying to upload 15GB but every week or so it just stops according to the Dropbox log.
Is there any know fix for this ?
Many thanks
