sasdotcom
Jul 06, 2017Aspirant
Dropbox sync hangs - Firmware 6.7.5
My ReadyNas 204 (firmware 6.7.5) still hangs on syncing with dropbox. The total size of the folder is 185GB updating 19GB every day (max filesize is 2GB). I have to restart it every 2/3 days, then...
JennC
Aug 04, 2017NETGEAR Employee Retired
civean
Aug 15, 2017Aspirant
Hi,
we have the same problem, after a couple of days of uploading our company share to Dropbox, the sync stops. (Yes, we have 1 TB space, and the synced files are 250 GB). Is there a way to restart the dropbox sync without toggling on/off in the admin interface (which means I have to re-add all sync tasks, slightly inconvienient).
We are trying to use Dropbox as external backup - so it is critical that all our files are available there and up-to-date - please fix this annoying bug!
Best
Christer Malmberg
