sasdotcom
Jul 06, 2017Aspirant
Dropbox sync hangs - Firmware 6.7.5
My ReadyNas 204 (firmware 6.7.5) still hangs on syncing with dropbox. The total size of the folder is 185GB updating 19GB every day (max filesize is 2GB). I have to restart it every 2/3 days, then...
civean
Aug 15, 2017Aspirant
Hi,
we have the same problem, after a couple of days of uploading our company share to Dropbox, the sync stops. (Yes, we have 1 TB space, and the synced files are 250 GB). Is there a way to restart the dropbox sync without toggling on/off in the admin interface (which means I have to re-add all sync tasks, slightly inconvienient).
We are trying to use Dropbox as external backup - so it is critical that all our files are available there and up-to-date - please fix this annoying bug!
Best
Christer Malmberg
GuyA
We scheduled an early hours reboot of the NAS each night which kick starts the Dropbox sync. It's not a fix but a workaround until the beta firmware is certified for general release.
Thanks
Thanks
- StephenBAug 15, 2017Guru - Experienced User
GuyA wrote:
a workaround until the beta firmware is certified for general release.6.8.0 is now released - though it might not be on the update services yet, it can be downloaded and manually installed. You can get it from here: https://kb.netgear.com/000045831/ReadyNAS-OS-6-Software-Version-6-8-0
It might be worth a shot. The release notes don't say anything about dropbox, but I don't think the bug fix section is comprehensive.
