Flomer
Dec 07, 2016Tutor
Dropbox Sync is changing EXIF Data / Meta Data of pictures
HI all, last time I recognized that roundabout 20.000 pictures has the same acquiring date (23rd of July 2005). First I thought it is some wrong setting in my dropbox but when I had a closer look...
Dec 07, 2016Guru - Experienced User
I haven't seen this. Does it happen on a share that doesn't use dropbox at all?
Also, what firmware are you running?
Flomer
Dec 07, 2016Tutor
Hi Stephen,
I was syncing the share "pictures" to dropbox with the dropbox sync function on the "cloud" section on Admin page.
I'm using 6.6.0. But not sure when it happend. I recognized when I was searching some picutures on dropbox "pictures" homepage. I had around 20.000 entris on 23rd of July 2005.
Br, Florian
- StephenBDec 08, 2016Guru - Experienced User
If you have some photos with the original dates, you could try putting them into a share that isn't synced with dropbox, just to see what happens.
