stgeorge
Mar 17, 2017Guide
Dual Duos on Same Network?
I recently acquired an older [i.e. legacy] Duo to perform some simple backups. While working on configuring it, I've had to setup a separate LAN using a different router. Once configured for my mai...
stgeorge
Mar 17, 2017Guide
OK- chalk this one up to "Bizzaro"
I looked on the back of my new (to me) Duo and no network lights flashing at all.... humm.... the cable is newer, so figuring that isn't the likely culprit, I pulled the end of it out of the router and popped it into the same port on the router as my other Duo. Lights immediately came to life. Ok- good. Now this is the strange part- when I plugged my older Duo into the port that wasn't working on the newer one, it immediately began to connect again and now all are visible and connected? That's really strange....
Sorry to waste everyone's time.
Thanks.
