etxbilr
Nov 20, 2014Aspirant
DUO expansion problem
Hi, i've got an DUO in X-RAID that I've performance expansions on a few times. Started with 500 GB driver, upgraded to 1 TB then 2 TB. As these are getting close to 90% I bought 2 WD 30EFRX after chec...
etxbilr
Hi StephenB,
I'm afraid you're absolutely correct. I was under the impression that I had a V2, but as I've just updates to 4.1.14 I'm proven wrong :oops:
As to the proposal to install the old driver I'm ahead of you. That was my first action after trying the new drives. So next step wil be to hunt down a new Netgear NAS as I'm quite happy with the performance. And as my network is bult around Netgear equipment why change :neener:
Thanks for your speedy respons!
BR / Bjorn
BR / Bjorn
