etxbilr
Nov 20, 2014Aspirant
DUO expansion problem
Hi, i've got an DUO in X-RAID that I've performance expansions on a few times. Started with 500 GB driver, upgraded to 1 TB then 2 TB. As these are getting close to 90% I bought 2 WD 30EFRX after chec...
Nov 20, 2014Guru - Experienced User
The RN102 is reasonable, but in general leaving some empty slots makes future expansion cheaper. So an RN104 might be more economical long term (starting it out with 2x3TB). You can expect around 70 MB/s read speed and 50 MB/s write speed - a lot faster than the duo v1. That is with antivirus turned off.
An RN314 will give still better performance (similar to the x86 ultra). Though it is more expensive of course.
