zmocar
Sep 29, 2013Aspirant
Duo operations lost after power outage - Need advise
I have the the Duo version 1. A power outage/brown out occurred and it is not working correctly. I cannot connect with Raidar and drives don't show up on my network any longer. The unit is running w...
Sep 29, 2013Guru - Experienced User
You can also try turning off the duo, and connecting the first disk to a PC. Linux Reader (http://www.diskinternals.com/linux-reader/) is a freeware program that should let you access the data, and copy it off. (That assumes that the data volume is intact, but the OS or hardware has an issue).
