sandheep
Sep 18, 2015Aspirant
Duo to Duo Backup Hangs
Hi! I've had my 2 ReadyNas Duo v1 NASs (RAIDiator 4.1.14 [1.00a043]) backing up from one to the other nightly without issue for the last several years. The units are at different locations with ...
Sep 18, 2015Guru - Experienced User
Are you running rsync over ssh, or normal rsync?
sandheep
Sep 21, 2015Aspirant
Stephen--
As far as I am aware, just regular rsync. I don't see any option for rsync over SSH, and I have not installed any 3rd party plugins to do so.
Any other thoughts?
Thanks!
Sandheep
- StephenBSep 21, 2015Guru - Experienced User
Rsync should be using port 873. You can check to see if that port is open at both ends at http://www.canyouseeme.org/
Then create a small test share on one system, with just a couple of files. Create a new rsync backup job for just that share, and see if it works.
- sandheepSep 21, 2015Aspirant
Stephen--
Hmmm...I actually have 2 backup jobs that run at 2am--the main one which i've been having issues with, and another one that's contents rarely changes (this has been running issue-free for years). i went ahead and made some changes to the contents of the 2nd job for the sake of a test--we'll see how things look by tomorrow.
also, i've verified that port 873 is open on both ends.
Will report back tomorrow.
THANKS!
Sandheep
- sandheepSep 22, 2015Aspirant
Stephen--
So the 2nd backup job ran successfully; however, the 2nd job was aborted since it's previous instance was still running.
Do you have any other thoughts or troubleshooting tips?
Thanks!
