mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
Etz
Only X-Raid mode has capability to expand.
And you cannot change modes "on the fly", factory reset is needed for that and it will destroy your data.
So you have to backup your data first and do factory reset afterwards then you will be able to select operating mode from RAIDar.
Also factory reset will align your new 2TB disks properly to get most performance out of them.
There is a very useful article, why sometimes "factory default" is the best way for doing HDD changes on Sparc based units.
http://www.rnasguide.com/2011/06/22/why ... -readynas/
What firmware version are you exactly running?
