mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
mgrzywacz
Ah, I see. Darn, didn't realise that. Would you recommend I use X-Raid on the reset? I chose RAID1 thinking it's a standard format so if my NAS died for some reason it would be easier to get the data off the disks - but maybe this is incorrect thinking?
My Duo has RAIDiator 4.1.10 running. I always update it as soon as a new release is available.
Are there simple instructions somewhere on doing a factory reset?
Now to go run a loooong backup to an ext hard drive. lol
Thanks for the help :)
