mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
Oct 21, 2012Guru - Experienced User
XRaid is layered on top of standard RAID, so the volume itself uses a normal RAID format. So you probably should have picked X-Raid when you set up your duo.
mgrzywacz wrote: Ah, I see. Darn, didn't realise that. Would you recommend I use X-Raid on the reset? I chose RAID1 thinking it's a standard format so if my NAS died for some reason it would be easier to get the data off the disks - but maybe this is incorrect thinking?
However, since you are expanding to the hardware limits of the V1, it doesn't really matter whether you stick with RAID1 or switch to X-Raid. No future expansion is possible either way.
The only possible advantage of X-Raid I can think of is that it would allow you to move your disks to an NV+ v1 and expand from there. With RAID1 you could also migrate to the NV+ v1, but wouldn't be able to expand. It seems unlikely that you would actually do this, given that the v2 came out a year ago.
