mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
mgrzywacz
Great info, thanks guys. It's big help to know that.
Even though, as you stated Stephen, I'm taking the Duo v1 to it's capacity limit, and so it doesn't make much difference, I think I'll pick X-Raid on the reset.
Thanks again :)
Thanks again :)
