mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
mgrzywacz
Oct 22, 2012Aspirant
I've had a look at the factory reset options at the page: http://www.readynas.com/?page_id=5029 ...but I'm left a little confused.
What's the correct method for a Duo v1? Is this simply it:
1) Press in the switch in the pin hole on the back and release.
2) then power on but hold down power button until the led flashes twice at the 30 second mark and let go.
3) now sit and wait?
Btw, is it the blue power button that flashes or the hdd led's? Just want to check this as my finger will be cover the power blue led in the button! lol
Thanks again for helping a total newb!
