mgrzywacz
Oct 21, 2012Aspirant
Duo v1 expansion: 2x 750GB to 2x 2TB - But Volume Not Larger
I had 2x 750GB Samsung disk's in my Duo v1. One disk recently failed, so I decided to upgrade to upgrade both disks to 2x SeagateBarracuda ST2000DM001 disks (they are on the HCL for the Duo). Fist ...
mgrzywacz
Oct 22, 2012Aspirant
OK, just figured out what I was doing wrong...
I thought I was looking for *2* flashes at 30 seconds - when in fact if holding down the reset button, the disk led's will only flash *once* at 5 seconds and then only *once* again at 30 seconds - this is when to let go of the reset button for a factory reset. I was somehow interpreting the instructions for this procedure incorrectly - doh! Anyway, I hope this helps others not fall in to the same trap I did.
